Help w/04, No Pw Windows, radio or gas gage | Ford Explorer Forums
Louis Young
Hattiesburg Mississippi
I am trying to help out a friend who power washed the under hood area of her 04 Explorer 4wd. The power windows are now dead, the gas gage no longer works and the radio is dead.:rolleyes:
Apparently they swapped fuses a few times and never could get things right, and asked for my help. I have good fuses in there. Voltage going to the fuses. Tested the pw window thermal circuit breaker. Have power to the circuit breaker. I am really out of ideas.
I have not opened up the fusible links under the under hood power box, but wonder if that should be my next step...
And ideas guys?? Thanks!
Which engine does it have, V6 or V8? Auto or manual transmission?
oops...sorry guys...4wd....V-6.....Auto.....
Also...nothing else seems to be wrong....Checked electrical all over....drives fine...etc...etc...etc
Thanks !!
Did you check those fuses? Couple of big ones. . .seems related to delayed accessories circuit, maybe a relay?
Went through the fuses underhood...checked thermal breaker under there...
delayed accessories circuit there is a relay but i'm not sure where?
The location should be shown in the owner's manual
Did you ever find the solution I'm having the same problem with mine could really use your help thanks
