ndjidem
- April 29, 2024
- Bamako
- 2006 Eddie Bauer edition
I have an issue with my 02 Explorer with the P1131. I used forscan to reset the code, but after driving a while, it comes back. I have cleaned all 4 oxygen sensors that were not cleaned since. I checked the exhaust for air leaks, but the code is still coming up. I need help now to guide me forward. Below is the complete diagnostic result with forscan
===OBDII DTC P1131-C===
Code: P1131 - Lack of HO2S11 Switch Sensor Indicates Lean
Status (-43):
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
Diagnostic Trouble Code details
HO2S11 not switching correctly. Sensor indicates lean.
Air leaks at the exhaust manifold
This DTC may be caused by :
Low fuel pressure.
Manifold vacuum leak.
HO2SHTR11 Heater Circuit Malfunction
===END OBDII DTC P1131-C===
Status (-43):
Low fuel pressure.
