Help with noise? | Ford Explorer Forums
Help with noise?
ixbigybxi
Logan,Utah
95' Ford Explorer Limited
I am hearing a clicking type noise on the drive side front of my 95' limited explorer. It sounds kind of like a CV joint but it does it when I am going straight and turning. And it also seems like it doesn't do it all the time. Has anyone had this problem or heard of it and it so could someone help me out with this?
Brandon
A clicking noise usually points to a CV joint.
Clanking Noise
I just install the full X-Spec kit and I hear clanking noise also on the driver side up front. I hope its not from the kit.
Any sugestions?
Have you tried checking out your wheel bearings. See if your tie-rod ends and control arm bushings are okay. Those are my guesses.
