Help with reading test results | Ford Explorer Forums
melewig
97 Explorer XLT
Can someone please explain?
I obtained the following from my code reader:
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$01 CID:$11
- Rich to Lean sensor threshold voltage(constant)
Min: 512
Test result value: 857
PASS
TID:$01 CID:$21
Min: 512
Test result value: 851
PASS
TID:$03 CID:$01
- Low sensor Voltage for switch time calculation
Min: 0
Test result value: 461
PASS
TID:$03 CID:$02
Min: 0
Test result value: 512
PASS
TID:$10 CID:$11
Max: 45
Test result value: 1
PASS
TID:$10 CID:$21
Max: 45
Test result value: 2
PASS
TID:$41 CID:$11
Min: 63,744
Test result value: 140
FAIL
TID:$41 CID:$12
Max: 512
PASS
TID:$45 CID:$20
Max: 22,592
Test result value: 15,098
PASS
TID:$4a CID:$30
Min: 768
Test result value: 1,516
PASS
TID:$4b CID:$30
Max: 26,214
Test result value: 8,028
PASS
TID:$51 CID:$07
Max: 1,180
Test result value: 65,535
FAIL
TID:$51 CID:$08
Max: 1,180
FAIL
End of report.
