KIM SUK KYUN
- May 16, 2025
- South Korea gyungido
- 2021 explorer limited
Also I can use forscan. Should I bring in the previous coding? I really want to do it
Welcome to the Forum.Also I can use forscan. Should I bring in the previous coding? I really want to do it
I'm going to buy a used product and install itWelcome to the Forum. :파도:
Is the above-linked cluster what you are looking for, or are you looking to obtain one from an existing Explorer?
That’s going to be a little hard, because it has to be programmed to the car with correct odometer reading.I'm going to buy a used product and install it
비슷한 주행거리의 중고 제품을 구매하려고 합니다. 플러그 앤 플레이 방식만 필요한 건가요? 아니면 포스 샌(Force San)이 필요한 건가요? 연료계가 맞지 않는다고 하시는 분도 계시네요.그건 좀 어려울 거예요. 자동차의 주행거리계 수치에 맞게 프로그래밍해야 하거든요.
It's not plug and play, not something Forscan can do alone. You need to have Ford's special tool to program the cluster to your odometer, unless the cars electronics will freak out. By the time you by the special tool, and go through the headaches of programming, you will be as expensive as the complete already programmed kit I linked above.비슷한 주행거리의 중고 제품을 구매하려고 합니다. 플러그 앤 플레이 방식만 필요한 건가요? 아니면 포스 샌(Force San)이 필요한 건가요? 연료계가 맞지 않는다고 하시는 분도 계시네요.
I see....So do you think it will be difficult for other parts other than the mileage?It's not plug and play, not something Forscan can do alone. You need to have Ford's special tool to program the cluster to your odometer, unless the cars electronics will freak out. By the time you by the special tool, and go through the headaches of programming, you will be as expensive as the complete already programmed kit I linked above.
Yes.I see....So do you think it will be difficult for other parts other than the mileage?
I really want to change it... That's too badYes.
If you buy that kit you’d be able to do it not too hard, but doing it yourself isn’t going to be worth it.I really want to change it... That's too bad
I don't think it'll be worth it if I buy it for the kit price. So I was going to buy it used product($250) and install it, but I guess it doesn't workIf you buy that kit you’d be able to do it not too hard, but doing it yourself isn’t going to be worth it.
Yeah it’s not a cheap endeavor. With the Ford tool and the pain to get it programmed, you’ll be in the $1k+ range.I don't think it'll be worth it if I buy it for the kit price. So I was going to buy it used product($250) and install it, but I guess it doesn't work
