Hi, Long time Lurker, finally a member! | Ford Explorer Forums
wkd_exploder
Strongsville, OH
96 5.0 Explorer
I have a 96 Explorer AWD 5.0. Im in the process of doing a manual 4407 conversion and am also converting the front torsion bar suspension to Coil overs. Rear will be an axle flip, leafs over axle and a 3" body lift as well for clearance for maintenance and for the 35's I plan on running. The gears already purchased are 4.56's front and rear with a mini spool in the rear.
Im lucky to have a 96, as the 4407 swap is easy not having to worry about the speedo, since my speedo gets the signal from the rear diff :)
This site have been a ton of help and I will be a supporting member soon here!!:salute:
Spoke too soon. The 4407 doesn't have a provision for a sensor
