Welcome to this forum! You should find what you're looking for if you do a seach on this site. I'm sure that it was covered somewhere. Generally on this type of job, you remove the two hydraulic fittings on the rack & pinion, the flexible half shaft (a type of univeral joint), tie rods, and two lock nuts which connect it to the cross member.
