Gillettetg
- December 26, 2015
- Bettendorf Iowa
- 2000 Ford Explorer
Hello guys, I been reading this forum for a while now to find answers to my questions. But now it seems I have a unique question.
I built a home made gas vaporizer out of a paint can and lid and a couple half inch pipes. I removed the air filter box and made a little box to bolt to the MAF sensor I then drilled two 2" holes in the side of the box. And two 3/4" holes in the top of the box. I used the small holes to attach two 1/2" pipes from the box to the lid on the paint can. I also drilled 2 more holes in the paint can lid for vent pipes. So basically its like a bong. Only the water is gas.
I have an obd2 device that reads real time data. The system is effecting things. I can tell by my ltft and stft percentage changes. Sometimes I get -20 on ltft and 5 on stft. But sometimes I get -3 ltft and 40 stft.
The 02 sensor reads very low .050 ish when stft is 40. When the 02 sensor jumps to .800 ish the stft is -3 is and will sometimes go to -20.
Sometimes the ltft will be -10 and the ltft -8 and sometimes the ltft will be -23 and stft will be 3.
It bounces around.
So does the computer change something based on ltft that effects stft?
So like if ltft is -20 for 3mins does the computer make that a new normal and then move the number ltft to 0 so the stft can do the adjusting?
At this point I am just guessing at what this stuff means. All the info I can find only talks about troubleshooting. But I have introduced fuel vapors into the mix so I know my sensors are all good. I noticed that the numbers of stft and ltft stay more steady when the system is set up like normal. I have really only notice small gains in mpg.
It bounces around.
