How Bell tech 1" and 2" drop blocks and these camber kits ? | Ford Explorer Forums
SKYWLKR
Baton Rouge LA
96 XLT 5.0
How Bell tech 1" and 2" drop blocks look and work and these camber kits any good?
I got the 1" and 2" blocks from belltech and a Specialty Products Co. camber kit with just the ecentrics. they are the +or- 1.75 degree ones for a 95+ exp.
they ok ?
I got it all for $55 just trying to figure out what blocks too use and if this Camber kit will work..
how much will a 1-1.5" drop need to be adjusted?
they had 2.0+or- Moog cams for $15 but were out of stock..
but I dont think I'll need that much adjustment,I will deff need at least .5 of a degree of extra -camber to handle my driving.
any one?
would the 1" or 2" blocks look better with about an 1.25-1.5 front lower?
whats in the EE kit as far as blocks?
and what camber ecc. do they use?
will I only need the set of 4 or is that for one side?
I found another set with 8 plus some bolts that go to 2 degrees - or+ what are these for?caster adjustment?
