How pervasive is this water pump issue? | Ford Explorer Forums
Buy 2014 3.5 Explorer with 75,000 miles on it?
  • Do it, the water pump will be fine
    Votes: 2 100.0%
  • Run away far and fast
    Votes: 0 0.0%
  • Total voters
    2
  • Poll closed .
Prospect62
Upstate, NY
99 Sport
Hey guys, been a lurker for awhile and never actually owned an Explorer - but now considering the purchase of one. I'm looking at a 2014 Explorer base 4x4 with the 3.5 naturally aspirated engine. The truck has 75,000 miles and for the price I can get it at, I was very excited to pull the trigger.
Of course, in my due diligence that I always do before buying a model I've never owned before, I stumbled upon this relatively recent issue with 3.5 water pumps going bad and dumping coolant into the crankcase, thereby blowing the motor with little, if any, warning.
Even though I'd more than likely purchase a mechanical breakdown package through my credit union (which is quite robust), I still don't feel like having this happen to me. This truck would be the newest vehicle I've ever owned since I was 16 (I'm 36 now) and my wife would seriously doubt my adulting skills if I blew the motor a few weeks into ownership.
My question is, just how common is this issue? Is it limited to a small percentage of 3.5 motors? Seems to me that at every point in an engine's life, the water pump goes bad. It happens. It's a fact of life. But with the design of the 3.5, once it goes bad if you don't happen to catch the few little droplets of coolant from the weep hole, you're in for certain destruction.
Seems like an ass-backward engineering design, which Ford is known for and is the main reason why I've never owned a Ford in my 20 years of driving. I want to give an Explorer a try, but I need advice from the experts on whether or not this is a good bet to take. What do you guys say?
I think your questions, except for the should I buy part, have answers that can be found in the following thread on the topic;
http://www.explorerforum.com/xenfor...ter-pump-failure-leads-to-dead-engine.424482/ Also, see my post in that thread http://www.explorerforum.com/xenfor...ds-to-dead-engine.424482/page-15#post-3647956
I wouldn't worry about it, if you are find a vehicle from a Ford dealer with a used car warranty. Who knows what mileage and time this will be a bigger issue later on, right now its few and far between.
This engine has been around for awhile, all it takes is Googling the topic:
https://www.justanswer.com/consumer...-5l-ford-engine-water-pump-failure-cause.html
https://www.fordtaurus.net/forums/viewtopic.php?t=19812
https://www.fordflex.net/forums/viewtopic.php?t=15553
http://www.carcomplaints.com/Ford/Edge/2010/engine/engine_died.shtml
Just bought a 12’ Explorer with the 3.5 duratech . How widespread it the water pump issue
As title says my GF and I got a 12’ Explorer . I knew about the 3.7’s having the internal chain driven water pump but did not know the 3.5 had the same setup . So my question is how widespread / how many people are having issues . I really only hope I can get another 50k/5 years out of it so it will have 150k on it . I’ve been reading online ( which usually makes problems seem bigger than what they actually are) but it seems like there is far more than just isolated issues with these
Welcome to the Forum.:wave:
Your thread was merged with this one on the same issue.
You may also want to check out; Water pump failure leads to dead engine
There are a few other threads on the failures you can find using the 'Search' feature (upper right).
Pete
