dont know if it helps but this is a page from my factory service manual. It says what parts to remove to get the actuator out.
Remove the parts in the order indicated in the following illustration and table.
To remove individual parts, only carry out the listed steps: Part Steps
Exterior door handle 1, 3-5
Front door latch 1, 2, 6-14
Front door lock cylinder 2, 3 (1 exterior door handle nut only), 4
Door lock actuator 1, 2, 6-18
Door ajar switch 1, 2, 6-16
Item Part Number Description
1 22152 Exterior door handle actuating rod
2 14A584 Electrical connectors
Removal Note
3 W705817 Nuts (2 required)
4 21991 Door lock cylinder (if equipped)
Removal Note
5 22404 Exterior door handle
6 — Bolts
7 22401 Front door speaker
8 14A488 Electrical connector
9 21852/3 Front door lock lever rod
10 — Bolt
11 — Interior door handle (part of assembly 219A64)
12 — Interior door handle cable locators (part of assembly 219A64)
Removal Note
13 N811471 Screws (3 required)
14 219A64 Front door latch
15 — Electrical connector (part of assembly 219A64)
16 14018 Front door ajar switch
17 — Electrical connector (part of assembly 219A64)
18 — Front door lock actuator
To install, reverse the removal procedure.
Item 2: Electrical Connectors Removal Note
Disconnect the door latch jumper harness electrical connectors.
If removing the door latch, disconnect the door harness electrical connector.
If equipped, disconnect the key cylinder switch electrical connector and separate the locator from the door frame.
Item 4: Door Lock Cylinder Removal Note
Release the lock cylinder actuating rod.
If a new lock cylinder is being installed, remove the retaining clip, the lock cylinder lever and the lock cylinder switch.
Item 12: Interior Door Handle Cable Locators Removal Note
Release the cable locators from the door frame.
