HVAC Air Flow Lever Replacement FOUND! | Ford Explorer Forums
HazyMage6
Monroe, Ga
2003 Ford Explorer XLT
Callsign
Mage
Hey all,
It's me again. So I replaced my blend door actuator about two weeks ago because it was skipping bad when going to heat. I always had the problem that my air flow only came out the center vents no matter what mode you put it on. Yesterday I pulled the glove box down to see the vacuum motor thinking the motor wasn't working, when I noticed that the lever it connects to is broken. I have searched this site for a fix because I don't want to pull the dash and put a new box in. People mentioned getting a company to 3d print the part if someone would help with the cost. Being someone who took engineering in high school since a freshman, I decided to see if anyone has made a model/fix for the lever that you can 3d print. Low and Behold, I found one!! Someone has made a fix for our lever problem using a 3d printer! He has even refined the design after testing it himself. I have included a link to the site where you can find the files below. A little recommendation when printing it is to make sure your infill is atleast 50% or higher. If you have any questions on printing it let me know as I am a 3d printing snob myself.
2004 Ford Explorer Blend Door Lever Fix by seanauff
Thanks you all,
HazyMage6
(Mage)
Seems like it's just a matter of time before someone makes a business out of replicating all these crappy plastic parts for older out of production vehicles. When they break, if nobody has any new old stock you are either going to the junkyard or are out of luck.
