I am just getting started. | Ford Explorer Forums
6WarChaBur9
Sacramento California
2001 Sport
I just got a 2001 Explorer Sport that has a power window control switch problem and I can't find a new switch. I put a junkyard replacement in it but the problem returned after one successful down/up cycle. Is there a possibility that a fuse or something else is causing this malfunction? Why can't I find a switch? I also have a rear tailgate actuator that is not working properly. Any tips?:exp:
can't speak for the rear actuator... but the front...replace the motor. chances are either you got ANOTHER bad switch (doubtful-but possible if window was down out of vehicle you got it from) OR the motor is bad.
welcome
