I drilled the airbox today | Ford Explorer Forums
  • Thread starter Thread starter BoatsRcool
  • Start date Start date
B
BoatsRcool
I followed some advice,
and drilled a small part of my airbox today.. I haven't driven it much yet, but it sounds cool when you gas it. I also got a K&N filter.
Drilled Air Box
Let us know the results!! I am thinking of doing the same thing, but I would like to hear from more people what it changed. Thanks-
BoatsRcool
Make sure you re-set your computer so it can adjust to your new modifications.
Disconnect the negative battery cable for 10 minutes, then reconnect the cable. Take a short trip 10 - 15 minutes so the computer can readjust itself.
i took the pos. and neg. cables off while I was drilling the airbox (about 30 min.) so that would reset it right?
Yes, definitely the right thing to do.
ok well I still havent driven it much, but I have noticed the idle is a little higher.. most of the time.. is that normal? well when its cold its a little higher.
check this out:
Dead Link Removed
Dead Link Removed
i sometimes notice a little lag when i hit the gas slightly, but other than that, have had no problems..... yet
