I need some help inside my driver's door. Broken handle and latch. | Ford Explorer Forums
FAS88
2001 explorer sport 4x4
My door latch and outside handle have broken and while preparing to install the new latch noticed some other broken parts . Does any one know of any sites where i can get some of these parts besides going to ford? I need a retainer ring that holds my cylinder lock in the door. also the power door lock motor snapped .. ( damn cheap plastic ) Also my door handle is broken and I need to know if there is something like an adjuster nut or something in between my handle and latch on the rod? It has a threaded end?? Thanx alot , Scott
ps.. hope this makes some sort of sense to someone
welcome a good bet is to go to a junkyard that lets you pull parts, i had a similar problem with an '89 mazda mx6 where the outside handle wouldn't open the door, i pulled one off a different car and got it color matched free (the shop was in the process of painting a black car) and put it on cost $15. good luck
