i need some info | Ford Explorer Forums
i need some info
pinto21632
redbud,illinois
98 explorer
i have a 95 xlt explorer i have a couple of problems i dont know if they are all tied togeather or differant things first off the number 10 fuse keeps blowing the over head console goes out when it blows the next thing is my back window defoger the indicator will not light up the fog light switch will not light up eather but i had to take out the relay for the heater motor because it was buzzing im going to get a new one does anything eles run off of the heater relay . last the four wheel drive has worked all winter the other day i went to put it in 4auto and it did nothing when i first start it up the 4 auto and the 4 low light both comes on but when i turn the switch it does nothing no light and no lock in sound its dead . o by the way i do have the rear radio and heater controls. everything eles works cig lighter back window wiper the radio dome light in the over head console all works .i know its alot in one post but it all seem to act up all at the same time so i dont know if is all the same problem or differant things sorry it is so long but i need help bad
a bad ground somwheres could be causing that, either look for a bad wire somwheres or bring that to a electric shop to trace down
