I seem to have same problem as others | Ford Explorer Forums
ralasa41
oz
ok next problem , Im fitting transmission back in ( 1997 5r55e ), I fitted the torque converter all went in all the way was knocking at the back on the case,
which is right, I took it out so I could make up a thing to hold it in , now when I fitted it again it wont go all the way in ???, I also noticed the input shaft from the gearbox was not moving in or out any more, before I think the shaft would have pulled out, its not the 2 splines not lining up , any ideas thx Pete
ok now
I did some searching and found the answer in other posts. cheers
