FNFAL
- November 18, 2009
- Illinois
- '99 Explorer Sport
Hey guys, I would appreciate your input here. I just picked my '99 sport up from the mechanic. He replaced the front left wheel bearing. While driving home I noticed wheel chatter when turning, felt like it was in 4wd.
I can hear it clunk into 4lo and and back out when I switch it. So the switch and dash lights seems to be working. The wheel chatter is not always the full on hard like when its switched to 4hi on dry pavement, except for a couple times. Usually just notice some grabbing and vibration.
I tried disconnecting the battery to reset the computer, still chatters. Tried unplugging the harness to the transfer case shift motor, still chatters.
So does that mean it's a mechanical issue if the problem persists with the harness unplugged? Something came apart in the transfer case?
The wheel bearing replacement would not be involved in this would it? Seems odd that is when the problem started.
