budwich
- May 4, 2005
- Ottawa, Ont
- 96 XL
I have changed out my IAC a while ago (8 months) with a "non-name" ( ie. NAPA part) because of the "moose" problem.... that problem has gone away..... not good especially during hunting season...
Anyways, the idle seems to be high (800-900) even after throttle body cleaning, linkage lub, etc. I have disconnected the battery for reset a couple times with no change.
One thing that I noticed from my old IAC and the new one is that they seem to be very hot... almost to the point of not being able to touch the motor body of the IAC.
I was wondering if this is an indication of a problem ( low resistance... too much current, too much heat) or if these things run that hot. Recently, I have had idle surges when I go to hit the brake at an intersection, the truck speeds up to 1500plus rpm... almost scary.....and actually releasing the brake appears to cause an RPM drop back to 800-900. I have seen a couple posts about this being an IAC problem but I have trouble believing that the replacement is bad already. So how hot is your IAC????
One other thing that I have tried per some postings is disconnecting it, the idle then goes down to around ~600 which seems about right.
