Red Delta
- July 24, 2011
- SW Ontario
- 97 Sport
This 97 Sport (5 speed 4WD) is a bit of a project.
It snowed here on Friday and I had to shuffle it around to gain access to my garage. When I stepped on the gas, the rear wheels started to slip and I just expected the four wheel drive to kick in automatically. Instead, I got a huge shudder and no drive from the front wheels.
I put the switch on 4WD and still the same thing. Once I was rolling all was fine, until I stopped and started rolling again, while stepping on the gas, causing wheel slip. My driveway is on an incline and I was battling to get it back up. The banging continued as the rear wheels spun and finally, it seems like the front wheels finally caught and I was able to get up the driveway. I shut it down and went about my day.
I did a whole lot of searching, and nothing sounded as violent of a shudder as I am experiencing at low speeds in slippery conditions. I'm about to drop the trans for a clutch job, so any ideas that I can take care of while I'm in there would be greatly appreciated.
CV joint or bad t-case?
Did I mention that this is a serious banging and shaking with a nasty shudder? Just want to make that clear. Thanks.
