Installing keyless entry | Ford Explorer Forums
Frenchie
Perpignan, France
94, XLT
Hello all
I have a 94 XLT with central door lock, and I got a keyless entry device to install on the car.
Before I startt splincing everything away, I would prefer if the more experienced users here could give a quick look on the wiring diagram, just to make sure that I won't fry anything. I am pretty sure that the correct wiring diagram is the 3rd one from the top.
Anyway, let me know what you think.
Also, for something totally unrelated, I have to weld a bracket on the frame, do I need to unplug anything electric like the battery or the ECM or anything else ?
Thanks
return that one to where you bought it, ot wont work.
i put keyless on mine and had to buy this one
keyless from jcw
it is exeactly what you want and easy as pie to install.
the unit will fit right behind the driverside kick panel - where you will be wiring it into your locks.
Once I had the electric diagram for the mocks, it was actually really easy to install, and worked on the first try ;)
The hardest part was to find the actual location of the wires in the cab :D
The third one from the top is correct. listed below are all the wires needed for remote entry,remote start, or security. This information was obtained from www.bulldogsecurity.com from their you can look up just about any make or model
WIRE NEEDED COLOR LOCATION
12 VOLT CONSTANT YELLOW (+) IGNITION SWITCH HARNESS
STARTER RED/LIGHT BLUE (+) IGNITION SWITCH HARNESS
IGNITION 1 RED/LIGHT GREEN (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK/GREEN (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER GRAY/YELLOW (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( + ) BROWN (+) @ HEADLIGHT SWITCH
POWER LOCK PINK/YELLOW (TYPE C) IN DRIVERS KICK PANEL
POWER UNLOCK PINK/LIGHT GREEN (TYPE C) IN DRIVERS KICK PANEL
DOOR TRIGGER BLACK/LIGHT BLUE (+) @ UNDER DASH LIGHT
DOMELIGHT SUPERVISION USE DOOR TRIGGER
HORN YELLOW/LIGHT GREEN (-) @ STEERING COLUMN HARNESS
TACH GRAY/ORANGE @ ECM, in the PASSENGER KICK PANEL
BRAKE LIGHT GREEN (+) SWITCH ON BRAKE PEDAL BRACKET
FACTORY ALARM DISARM DARK GREEN/PURPLE (-) IN DRIVERS KICK PANEL
Yes I know this is an old post that I am replying to, and on some forums they think it is like trying to resurrect the dead but I need some clarification here...
I am installing a remote start on my 96 Explorer and the Yellow/Light Green wire is in a yellow covering or sheath if you will. I read somewhere that the air bag wires are encased in a yellow covering. I just don't want to hook this up to the yellow/light green wire and have it set off the air bags when I test my remote starter. :eek:
The connector that this wire goes to is fastened to the right side of the steering column. Is this the right one?
That's interesting but it still doesn't answer my question about the horn wire.
If your worried about air bags going off then your in the wrong section. This is for 1991-1994 they dont have air bags.what year is your truck?96..
Yes it's 96. I just did a search for the horn wire location and this is one of the posts that came up. I didn't notice it was for earlier models. Sorry.
