- March 16, 2013
- Woodstock, GA
- 04 Ford Explorer 4.6l
My '03 Mounty was said to be losing antifreeze. It has reportedly over heated. I filled up the overflow today and fired it up. Engine runs smooth, no miss.
I noticed the 'check valve' at the front of the engine (hose going to heater core?) was leaking fairly good. If left alone it'd certainly have drained the system and caused an overheat situation.
I added two qrts. of oil to it when I picked it up. It was clean today until I added water to the system. If I check the oil immediately after shutting the engine off, it's a little cloudy. Once it sets a bit, it really looks normal.
When running the engine, I get white exhaust that smells sweet. So, the hose leak isn't the only leak. I did have a helper watch the overflow tank for air bubbles when I started the engine, nothing.
So, if I don't have a blown head gasket, where else would water enter the combustion chamber? The shop told the previous owner that the intake was leaking. Would a leak here put water in the combustion chamber as well as the crank case?
