Most people over-tighten these links. On some vehicles, that might not create a problem. On these, it leads to broken rods. They need to be tight enough, so that the there is no "play" or "slop" causing things to clunk. But they need to be loose enough, so that the rounded bushings can rotate within the "cup".
If you get a kit that has softer bushings, it probably does not matter, as over time, they will simply wear out and rip like yours. They really do not rotate. They just smoosh and compress as needed. Other kits (like the Moogs with the white poly bushings) are harder material. It's these that can cause problems with overtightening, since they really do not compress much. They need to be loose enough to rotate a bit in-use. I broke a set within a month, before I talked to a Tech at Moog. He told me:
1. Tighten just until you can no longer turn the center sleeve by hand.
2. Then tighten 1 more complete revolution, and no more.
Again, any tighter, and the rods will break quickly. Any looser, and you will have noisy play.
