Is this the correct size for longer torsion bolt? | Ford Explorer Forums
beach
south florida
Coyote F150
M12x1.75 100mm
Lifted the truck and did a TT in front but the factory bolts aren't enough to make it level with the rear. Found a Fastenal place by me. Also if using new bolts, do you use thread locker or anything for the new torsion bolts?
edit - also if replacing the bolts whats best to remove the factory ones, just jack the front up so suspension hangs and then remove?
50+ views and nobody knows? Lol. Now I'm seeing some people say you have to get longer bolts and round them off. Will the fastener place do that?
edit - they won't do that for two bolts, can, but not worth the cost to send to their metal working facility for shipping/labor for 2 bolts. The shop I had to finish the front suspension (gave up on the LCA lol) said they can do it (round the bolt off correctly for the torsion bar).
