It never ends! More codes. | Ford Explorer Forums
checkedout
Falling Waters WV
1996 Explorer XLT
CEL came on yesterday, P0304 and P0153.
Checked the plug and wire on #4 and they looked good. Both are only a couple months old and Motorcraft. Oils fine, coolant is not going anywhere and it's running fine. I was hoping to see the wire melting to the back of the EGR, but it's fine. Just once I would like something to be easy.
Check that plug again!
I would venture to say that there is probably a little more of a coating on one side than the other. I suspect lower intake gasket problems and that you might be loosing small amounts of coolant now and then. #4 is a common problem area and the 153 indicates the O2 sensor is being poisoned.
I just had the heads replaced in October. :-(
