I just bought a 03 XLT with 105k on it. Took it to a shop beforhand to check it out and they told me there was a little oil coming from the rear main seal and it should be changed. I got the guy to take the price of the repair off how much he was asking, as the shop said this is a common problem that they fix all the time.>>>>>>>>>>>>
Mjo20,
Just curious here, what was the price $$$$ quote the repair shop gave you to repair the rear main oil seal on your 2003 Explorer? I'm not positive on this, but I'd imagine the transmission would have to be disconnected from the fly wheel/engine and moved a few feet backwards for room to work on the oil seal or totally removed from the vehicle.
>>>>>>>>>>>>>>My question is I don't have any service records for the car, so is there anything I should do right away? Should I take it in for the 100k service? Should I get a transmission flush at the dealership? Do I need to fix the rear seal ASAP? Any help on what to do now to make this thing last would be great!>>>>>>>>>>>>>>>>>>>>>
I just bought a 2005 Explorer 4.0l with 82,500 miles on it back in January. MY rule of thumb for any high mileage vehicle I buy is update any normal wear and tear parts you can afford do at that particular time. I purchased a 3 year warranty with my vehicle, but I've already sunk some out of pocket money on changing the plugs, wires, fuel filter, air filter, fuel injection cleaning, rear diff gear oil and front and rear brake pads, greased front and rear brake caliper pins and oil and filter change. I also checked and topped off the front axle housing with gear oil and made sure the transfer case is full as well. I will be changing the radiator coolant soon and most likely the thermostat and possibly some of the hoses. Once you check or replace some of these things, you pretty much know where you stand with the vehicle. You should also lubricate anything that needs lubricating and use anti-seize compound on any nut and bolt you take apart where that product can safely be used. The transmission flush you mentioned is not a bad idea, just make sure they change the transmission filter as well. Where I live in Western, NY, the partial transmission flush (pan and filter only) service usually runs around $75-$100 and a complete transmission flush (pan and filter plus Torque Converter) included, usually runs around $139-$169. Good luck with your new vehicle.
