Just wanted to say Hi. | Ford Explorer Forums
Mac Daddy
Central Florida
1997 Ford Explorer XLT
I just purchased a broken down 1997 Explorer XLT from a guy who said the oil pump failed. It has right at 100K on it.
Sure enough it has zero oil pressure.
I pulled the 4.0 OHV and pulled the oil pan and the bottom of the pan had a solid 3 inches of sludge...So much the oil pump screen was completely submerged in sludge and preventing any oil flow. When I tried to drain the oil nothing came out of the drain plug even though the dip stick showed the crankcase was full. Crazy!!!
The end results are the crankshaft is shot, Rod bearings and rod bearing journals are shot on the crank, everything else looks to be in good shape.
Rebuilding the engine now.....
Welcome to this forum! Could you make a step by step photo thread on rebuilding the engine?
I can try..... I have already torn most of the engine down and I'm only rebuilding the bottom end, or what is damaged... The rest looks ok.
The heads were just done 13 months ago so I'm not going to mess with them.
