Keyless entry/ignition only on Limited? | Ford Explorer Forums
mech
Motorbike
Is this accurate?
I just ordered a 2013 XLT and was expecting it.
Is this accurate?
Correct, you do get the number pad on the driver door B-pillar so you can lock your keys in the vehicle and open with the number pad.
To be more specific, does the XLT with 202A have pushbutton start?
Nope. You have to get the limited. Stupid if you ask me. Push button start has been standard on Nissan's for the last 5 years. At least give us the option to add it.
Is this accurate?
As other members have stated, Keyless entry/ignition is only available on the Limited. If you check out the Ford website and look under Models & Options, you will see that the XLT only has a SecuriCode™ keyless entry keypad . The Limited shows it has Intelligent Access with Push-Button Start as well as the SecuriCode™ keyless entry keypad.
