Keyless Entry | Ford Explorer Forums
Keyless Entry
lilminner24
Bonifay,Fl
93 XLT 2WD
Just got a keyless entry system for my 93 xlt. Can anyone give me advice on how to install it.What wires,color,location,etc.......
Just put my first one in and love it! Go to the bulldog security website and you can get a chart with wire colors. Use a volt meter to check the alarm inputs/outputs an make sure things make sense before you hook wires up. The directions I got with my kit sucked but I figured everything out. My system was a negative output system so I needed bosch relays to control domelight, horn, ect. If your truck has a five wire reverse door lock system you may need a doorlock relay or you can make one out of two bosch relays.
My keyless entry says,built in relays, that is the same thing right?? No need to buy relays correct??
You will be fine without buying relays then, and your truck does have the 5 wire reverse lock system... When I installed my alarm that lock system confused me a bit, and it took me 2 or 3 tries to get the locks to operate via the remote. :)
