Sammy76
- September 11, 2011
- Oregon
- 2013 explorer xlt
So since you guys are so awesome I'm kinda stumped here, maybe you can help. My 97 4.0 has been smelling kinda hot after driving for awhile but the gauge doesn't show higher than 1/3 . Today I notice coolant dripping from around the front passenger side and its feeling really hot. Not leaking from a hose but probably the plastic tank. While trying to locate the leak I took the cap off and notice the coolant isn't circulating. at first I thought maybe the thermostat was bad but the upper hose is hot and the heater blows hot air!
So, I'm not sure if I have a bad water pump and crapped out temp sending unit? Or could it still blow hot air with a stuck thermostat? any suggestions on how to test the water pump? I can't afford to take it to a shop rite now so any help is appreciated.
