leaky injector problem | Ford Explorer Forums
horhay
I'm having a problem with No. 6 injector. In the morning, I checked the No.6 plug and its wet, which I thought was a leaky injector. Replaced all the injectors and still has the same symptoms. When I first start the engine in the morning it idles rough but then smoothes out after warm up. Does anyone have any suggestions?
Could it be coolant on the plug?
welcome
I am actually posting this for my dad, so I will update the info later tonight.
The plug actually was gas not coolant. The first thing we replaced were the plugs, then assumed that the injector was leaking. After replacing all that, there is still gas in the No.6 cyl every morning causing a rough idle until it warms up. We have hit a road block, and can't figure it out.
