Led light bar turn on button help? | Ford Explorer Forums
JonL51
West Branch, Michigan
2009, Explorer XLT
Hi, I have a 2009 ex, and i was wondering if anyone knew how to turn these buttons into a switch for a led light bar. ive looked everywhere, just dunno. Thanks for any help in advance. (buttons on the left of course)
your picture isn't showing. I'm not sure what buttons you are talking about.
Oh I see. Those aren't buttons. Those are just blank covers. You will need to install your own button in it's place to control lights
any clue on how to do that or what ill need?
The blanks are not buttons. If you take that switch housing out and look at the back side, you will see it is empty. You have to put your own switch in
so i could buy a momentary switch, and hook it up?
I removed the blank on mine and located my bass boost knob..... my light bar switch is in the blank void below that where the adjustable pedal switches would have been and a digital voltage gauge .... there is alot of room back there for wires make sure you use relays and keep the actual power for the light bar under the hood close to the battery ... the only thing behind the radio bezel trim should be signal leads
