Lift and bodylift questions | Ford Explorer Forums
MikeRWK
Englishtown, Cape Breton Island
1996 XLT
Does someone make a 4" kit? are there any problems with a 3-4" BL? And are there ways to lift the IFS or for anything beyond 2" do i have to swap to a solid axle?
Both Trailmaster and Superlift make a 4inch IFS lift, but if you ask a bunch of people you'll get a mixed opinion, it get's you up in the air, but the down fall is you have to drop the torsion bar brackets down actually lowering your ground clearance, and you could easily do the TT/shackle with a three inch body lift and have just as capable a truck. and no there i no other way to lift the IFS, if you want to go more then 2 inches and improve functionality you'll have to do a SAS.
Justin
Thanks for the info, now does anyone have an answer to my bodylift question?
For our trucks, there is no actual body lift. You need to use a PA 853 kit from a ranger which is a three inch BL kit, everything will work, with the exception of there are two or three bolts that will need to be lengthened as they are not long enough. as well as you will need to play with the bumper brackets.
There is no 4inch BL unless you make one
Justin
Thanks
