Lifting my 95 | Ford Explorer Forums
Lifting my 95
SethD
Huntersville, North Carolina
'95 Eddie Bauer
I have the TT/shackles (153's) and I want a little more for 32's. What are my options? Is there a body lift that I can buy? What about suspension? Sorry about being so broad, just sick of searching at getting nothing! Thanks Guys! Seth D.
You can do a 2" or 3" body lift for about $180 (no labor). A suspention lift is going to cost you a minimum of $1500. If you are just looking to clear tires, I would definately go with the BL. Try a search for PA body lift.
Robb
Thanks for the quick response, however, explain to me the suspension lift, and also, the "No Labor" t hing with the body lift! That sounds like a better idea anyway, with a much better price. Thanks again. Seth
the 4" suspension lift basically uses brackets to drop everything in the front 4" to give more tire clearance. I think in the rear you can go SOA or use new leafs.
The body lift requires a lot of labor to install. It's not hard, just time consuming. The cost of the kit obviously doesn't include this labor. Many members have done it, so I suggest finding another member in your area with experience and giving them a few beers and dinner to help you out.
