limted slip on a 94 sport? | Ford Explorer Forums
GenLee01
New Durham, NH
2000 Explorer Limited
ment to put this in this thread. accidently put in modified explorations.
hey guys/girls. does anyone know how to tell if you have limited slip stock? i have a 94 sport loaded with everything including trailer/tow and 4.10 gears. thanks!
The easiest way, if you can be reasonably certain than no one has messed with the internals of the differential, is to check the axle code on the doorjamb, or the differential tag on the differential cover. I know someone has posted the meanings of the doorjamb axle codes here somewhere. If you check the differential tag, the first part of the second row will have a number that represents the gear ratio (373, 411, 327). If there's an "L" where the decimal would be (3L73) then you have the limited slip.
Next time please let the thread be moved, don't just start a new one.
sorry Alec, i tried to delete it but it wouldn't let me. i will next time.
thanks
