Hello, Can somebody tell me where this is located on a 2008 Explorer? My rear AC blows not-so-cool air while the front dash vents blow out very cold air. I have searched and read a lot of threads online and the consensus seems to be that the rear expansion valve could be the cause. I verified that my blend door works. Also is the expansion valve the same part for front and rear?
When you open the trunk it is inside the left side panel, where the switches for electric seats are.
I just got mine replaced and rear AC started blowing cold air right away.
I had issues in getting the expansion valve.
I'm from UAE and the ford dealer here wont sell expansion valve alone. They sell the valve along with the evaporator unit. The whole thing would cost about 200 dollars.
But I found a very similar expansion valve from the local spare parts shop for about 20 dollars. (Of GMC, but seems like both are made by the same manufacturer)
The work involves
- removing rear seat belt
- removing panels.
- removing AC gas.
I flushed and cleaned my rear AC system
Which took
- disconneting Coolant and Gas pipes from underneath rear left tire.
- taking out whole rear unit.
- flush pipes and evaporator unit.
- replace expansion vavle
- refit everything
- check for gas leaks
- refill AC gas.
I have taken pictures of the expansion valve and the whole replacement job.
I will post it sooner.
