BackBone
- December 21, 2012
- Redlands, CA
- 1997 Mercury Mountaineer
Hey guys, I've spent way too much time wheeling on the internet so I finally got the Mounty out on the trails and did a run with a friend up Rowher flats. Lots of hill climbing as we went to the top using an access road off of Bouquet Canyon Rd.
First off, I am thankful that I did the 4406 swap as having low range made the hours of climbing less stressful on my engine and transmission and led to needing less of the skinny pedal to get over obstructions.
What I did take away from my "first time ever" wheeling event is that at times I had trouble gaining traction. This was usually due to a wheel coming off the ground or not having as much weight on it causing the wheel to spin easier. My LSD in the rear is not tight (260+k miles) so I was almost open front and rear. In watching my friend go ahead of me - he was in a lifted Land Rover with good articulation but with open diffs - I noticed that he rarely spun his tires because he was able to keep all four wheels on the ground most of the time. Of course, with the added clearance and articulation, he was able to navigate much more difficult lines than I could. Nevertheless, I also noticed at times his tires spinning making obvious his lack of lockers.He was impressed with the Mounty, though. And I never got stuck. I just had to choose my lines carefully and also follow his spotting. I made it up every hill! My wife and kids were with me. My wife told me that I better not sell my Mounty! She said it was awesome! She understands now what I was doing out in the driveway!
Choosing the right line is the name of the game. With the right line then you are going to have traction. Traction is awesome! If you have traction then you can move. All four tires on the ground is awesome. If you have all four tires on the ground then you have more traction than if a tire is in the air.
Now to my point - or maybe question: While my buddies rig did great, I am never going to have the articulation up front that he has. I know for a fact that the reason I lost traction was because at some point one wheel of an axle stopped spinning while the other spun without much traction. I feel that if I had a locker in the rear, that I may have never slowed in the areas that I spun tires in. Yet at the same time, I also believe that if I had more flex in the rear that would have helped as well.
My conclusion is that I need both articulation and a locker in the rear especially because there isn't much I can do for articulation up front short of SAS, and a locker up front is costly and can cause damage if not used properly. I know I can get some limit straps up front and will be doing that, but it seems most of the work has to be done in the rear of the vehicle.
Eventually down the road, I'd like to swap to higher gears (4.56's) and would do a locker at the same time. For now my plan is to beef up the LSD, bodylift - which I did not want to do, but now realize that it will help with tire rub during articulation and also help if I move up to 35's instead of the 33's - and quick diso the rear swaybar for flex.
I would like to practice choosing the right line on flat ground as opposed to going up hill to reduce "pucker factor".
What do you guys think? Am I thinking correctly here? Any helpful suggestions would be appreciated.
Looking forward to my next run!
