Johnny Glenn
- September 2, 2009
- Charleston, SC
- 02-04 Explorers
Thanks for looking in - I've got an 02 Limited that has got some trans problems. It tried replacing both servos w/ no luck. It did seem someone had been there before as bores had brass fittings. The trans has a long first shift - It will rev up to 4 or 5k rpm and then once I let off gas it will shift. Is there anything worth trying before sending for rebuild. I can remove unit but I need something to look for? Thanks
