Looking to put black lug nuts on 2023 timberline any suggestions? | Ford Explorer Forums
rmester
cape coral
2023 ford timberline
An alternative would be vinyl lug caps that you can get in black.
Thanks for the feedback will look into that option. Really want to install real lugs
I bought this https://www.amazon.com/dp/B007QB5AVA?tag=seriouexplor-20
They are solid lug nuts, not capped like OEM and come with locks and all are black. But be forwarned, they require a 22mm socket so you better buy a couple of sockets, one for home and one to keep in the car. And get a breaker bar to keep in the car to use with the 22 mm socket because the factory lug wrench won't fit anymore.
Thank you will check it out
I’ll second the vote for McGard. I’ve used mystery brand, Gorilla, and now using McGard Splinedrives on my Paseo. Also using OEM locking lug nuts (made by McGard) on my Accord.
Listen to the Rolling Stones, and Paint It Black.
Did you find any? I did the same thing with an Edge that I owned. I got mine through Discount Tire, but you can probably find them cheaper on eBay or the like.
Welcome to the Forum. :wave:
Spray-on rubber coating like Flex Seal or Plasti Dip (I've used this on mine). Less than $10.
