thebadj
- February 24, 2005
- Greater Houston Area
- '91 Exporer XLT 4X4
No trans tech ever posed the idea of what I found. Driving on errands, all fine, except noticed gear indication slipped to one notch off: reg D was now neutral; engaged in 3rd's notch. Then at next start-up, the column shift went limp..no 'resistance' from trans. Shift cable fine; worked the trans shift lever full range. Because my rig is worn...275K mi....I went networking to see if I could scope out the problem area before putting it up on a rack...and going at 'their' mercy. All along, I believed it was mechanical linkage, not anything hydraulic. Sure enough, dropped A4LD's pan and found the detent "rooster comb" or sprocket was loose on the shift shaft. It had slid sideways off the key/flats on the shaft. So I repositioned it, and because it was too tough to try to use a 15/16 wrench to tighten the shaft nut, I used a slender punch and did it that way: fine. Got in car; worked lever; felt back to normal, just dry. So I buttoned it up, refilled it, and started it up. Immediately went limp again. I'm going back under there for a red hair treatment when the rain stops. Any advice? This has to be the cheap route. Do I have to drop the valve body to change out comb/shaft or [?] ? I'm thinking I can then fix on bench or take the valve body to a shop for them to do it. If the shaft fit is wallowed, I've even thought of sticking a weld up in there. A rebuilder could knock that off with a die grinder. But that's not how I was raised. All advice welcome. John
