Loud Humm under the hood | Ford Explorer Forums
BOSS3024ME
Oysterville Washington
96 Eddie Bauer
Hi all
I'm new here and have had my 96 EB for about 5 years.
It has a 4.0 with a K&N FIPK other than that the engine is pretty stock.
My wife drives this thing back and forth to work (5 Miles each way) it now has 100000 miles (just turned)
It has started a intermittit humm under the hood at idle it is preety loud, First I thought the FIPK was doing it (needed cleaning) so I cleaned it and tightened all the bolts.
Started it up no noise :)
Came home from work on Friday loaded it up to go to the NHRA nationals in Seattle fire it up (it was warm the wife had been driving it) and you guessed it HUMMMMM
Sure sounds like its in the air cleaner area and it goes away when you come up on the throttle.
It runs great does not use oil does not throw any codes just now this HUMMMMM
Any ideas ???
Thanks for the help
Paul
Idle Air Control unit. It's actually near the engine and reverbs to the airbox. Do a search on 'IAC' and you'll find all the info you need.
