92'WhiteWolf
- September 24, 2017
- Alabama
- 92' Explorer XLT
So today I decided to change out my thermostat in my 92' with 126K on it. I run a mechanical temp gauge in the cabin to get a more accurate reading(never liked the dummy dash gauges), but it has never pushed the needle past 150 degrees and I wasn't getting good heat out of the vents. Thinking the stat could be suspect, I went ahead and purchased a new 195 degree w/ seal, and also went ahead and changed out the ECT temp sensor while I was in there. Once the water neck came off, I noticed that the thermostat looked to be either original or hadn't been changed in ages, and also looked to be slightly stuck in the open position. I cleaned the mating surfaces up and installed the new stat. Put a little antifreeze mix in the radiator and cranked it up to start the burping process. I originally tried putting the truck on ramps prior to starting the job, but my carport is smooth concrete and it just wasn't happening lol. I would have also just jacked the front end up, but didn't have a jack that I thought would raise the front of the truck up substantially enough to burp. Anyway, it took me about an hour with the truck sitting on level ground to bleed what I thought seemed to be all the air out of the system. I did drain most of what was in the radiator before I started the job because I wanted to put fresh coolant in the system. Did that create an even bigger air pocket? My question is, how do you know when its done burping? It just seemed to keep spewing it out every couple minutes. Either way I finally was able to top it off, put the cap on it and went for a test drive. The needle never got over the 198ish degree mark and the heat will blast you out now which is great! It seems to even have made the truck have more power too! Overall I'm very happy with the outcome of this job done.
