Low 4x4 panel light question. | Page 2 | Ford Explorer Forums
Just to clarify.... In order to shift into and out of low range, you must be stopped, in neutral, with your foot on the brakes, THEN flip the switch.
Glad it was a simple issue.
And I'll second the vote for opening the owner's manual. It's not just used for ballast on the passenger side... ;)
-Joe
it is in the transfer case, whatever is wrong....but try what I just said, go out and try it and let me know if it works. put it 4wd low, then put the car in neutral and turn the knob to auto. Then put in drive and see if it will move
Your the man, i had the exact same problem and you fixed it!!! :salute:
