low gas mileage | Ford Explorer Forums
low gas mileage
mudslogger
horseheads new york
explorer 1993 sport
Hey i changed my oxygen sensors then i check my mpg and i am still gettin only 12-14 i have a 1993 ford ex any suggestions to what could be the prob?
Any other symptoms?
How's it running; at idle, cruising, WOT?
Do you seem to be running rich at all?
after i changed the o2 sensors it runs alot smother it accelerates grate doesnt seem to have any symptoms of any
Assume you cleaned the MAF, added K&N Filter, Platinum Plugs, new cables. Did you reset your computer after changing the o2 and cleaning the MAF?
Could it be your driving?
Try driving the truck for a tank with not letting the RPMs pass 2,500 - 3,000 max. Use the cruise control as often as possible, but not on start up
lol i did all of that when i changed them, i think it is because i put the wrong oil so it's taking more gas the turn the engine i picked up 1 5w-30 then the rest were (4) 20-50 thats what i get for not looking
Well try changing the oil then ;)
i use 10-30 what is the advantage of using 5-30? Should i use it also?
changing the egr netted me 2mpg. 5w30 is for winter because it is thinner. stick with the 10w30 for all season.
welcome to my world of poor MPG =[
Hey, y'all can't complain!
Troll and I can get as low as 6 or 7 mpg! I usually get about 12-13 city and 15-22 hwy though. He averages about 10 mpg. That's the tradeoff with 600 hp I guess :eek:
Better gas mileage. I highly recommend synthetic oil. I have recently changed from 0w30 to 5w20.
5w-30 vs. 10w-30
Actually, as stated earlier, 5w-30 is for winter, however, it's actually thicker than 10w-30. It doesn't freeze as fast that way. If you live in warmer states (Texas, Arizona, etc), 10-30 is all you need. And it doesn't take as much to turn the motor.
ya if i use synthetic oil my truck sometimes leaks so i stay away from that
