Mc2027
- September 17, 2024
- Pensacola,Fl
- 2013 Lincoln mkt 3.5L
Hey I have a 2013 Lincoln mkt 3.5L eco boost with 250k miles and I’m have a problem with my oil pressure it keep saying a low oil pressure when I came to a stop or when idling and it could turn off right away. So I connect a manual pressure gauge and it was within spec at 1500 rpm’s it was reading 50psi and the minimum is 30psi that’s what the book says. So I replaced the sensor and it did not come up for about a month but last week it started to do that same thing. I have already changed the oil and filter and there is no strange noises coming from engine. Is the main bearings going out or is it the oil pump if so why did the light stop coming on for a month the day the changed out the sensor? Should I replace the sensor again? I bought the sensor from napa for about 40$ could it just be the sensor again?
