Ford has a tsb for reprogram pcm for these concerns.
Printable View (48 KB)
TSB
07-10-12 VARIOUS DRIVEABILITY AND A/C PERFORMANCE QUALITY SYMPTOMS - 4.6L 3V 6R60 EQUIPPED VEHICLES ONLY
Publication Date: May 14, 2007
FORD: 2006-2007 Explorer
2007 Explorer Sport Trac
MERCURY: 2006-2007 Mountaineer
This article supersedes TSB 06-23-11 and 07-2-8 to update the Service Procedure.
ISSUE:
Some 2006-2007 Explorer/Mountaineer and 2007 Explorer Sport Trac vehicles equipped with the 4.6L engine and 6R60 transmission may exhibit various driveability and A/C performance quality symptoms.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Apply reprogram to 2006-2007 Explorer/Mountaineer and 2007 Explorer Sport Trac vehicles that may exhibit the following symptoms:
SYMPTOMS
Cold hesitation/surge
Long crank
Engine fan noise on cold start and A/C operation
High idle during warm up (cold engine)
Inaccurate Message Center average fuel economy estimation
Overheat indication at idle in gear in high ambient temperatures
A/C shutoff at idle in gear in high ambient temperatures
Lower than desired RPM during long deceleration
Install IDS or equivalent and ID the vehicle.
Update the PCM and TCM calibration using IDS release 48.13 and higher or 49.2 and higher. This new calibration is not included in the VCM 2007.5 DVD. Calibration files may also be obtained at
www.motorcraft.com. Since the TCM cannot be reprogrammed alone, reprogram the PCM/TCM together to ensure that both engine and transmission calibrations are updated to the latest level simultaneously.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
071012A 2006-2007 Explorer/Mountaineer, And 2007 Explorer Sport Trac 4.6L Engine, 6R60 Transmission: Reprogram PCM And TCM (Do Not Use With 12650D) 0.6 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
recal 04
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
