patternfall
- June 20, 2010
- Seattle, WA
- 1990 XLT
I swapped my destroyed original M5OD-R1 transmission (1993 Explorer XLT 4WD) for the same from a 1996 Explorer. Everything initially looked identical...
Except the top covers are different. The new '96 top cover is lacking a sensor, which research is telling me is the neutral safety switch. I have not yet retrieved error codes (I'm at work), but after driving for ~ 20 minutes the check engine light came on.
So regardless of the light, will leaving the plug for the switch disconnected (again, nothing to connect it to anymore) cause any issues? I would prefer NOT to use the old top cover, as it got pretty badly browned when the tranny melted its insides.
And lastly, if it does turn out to be the cause of the CEL, would shorting the wires trick it into thinking everything's ok?
