Manual t-case Swap Help Tailhousing issues | Ford Explorer Forums
dkchrist
Fayetteville, AR
93 XLT 4DR
I just scored a Manual 1354 out of a ranger for a song, 37,000 miles with all the goodies, but I have one issue:rolleyes:. I was crawling under my truck checking things and I don't have the mounting bosses for the shift linkage. I want to make this work but I need to get some info on the manual transmissions from the the gurus on the forum.
My transmission has the VSS in the tailhousing of the trans. I need to know what rangers/exs have the VSS in the tailhousing or the number of teeth on the drive for the vss in both the trans and transfer case so I can just extend the sensor to output of the t-case so I can source a different tailhousing and get the ball rolling.
Also, if anyone has a manual transfer case manual tranny combo in a SOHC truck or has done the conversion pictures would be awesome.
Thanks in advance you guys rock!
