koda2000
- September 2, 2011
- x
So today I decided to locate the blend door actuator on my '01 ST. Found it right where I expected to (behind the glove box, on top of the heater plenum, left of center). I removed the electrical connector, which I still have to check with my multi-meter. The two screws at the front of the actuator are easy enough to get at, but how the heck do you the one in the rear center. I'm not even sure I can get my 1/4" ratchet in there. I definitely can't get my hand in this space. Hoping one of you who've done this can offer some advice. Maybe my problem is electrical and I wont have to remove the actuator.
Question - How does the manual TEMP switch work? Is it a rheostat, like the dimmer switch, if it is I wouldn't expect to have 8 pins on the actuator's electrical connector. There seems to be 8 markings on the switch face plate, but it's not like the switch clicks as you pass each one.
