mxl4729
- April 20, 2010
- keyport, NJ
- 2003 explorer sport trac
If anyone has a better place to post this let me know.
My 2003 ford explorer sport trac has 85K miles and had a very bad Rattle at start up. if you let it sit for more then an hour or so it is very bad the longer it sits the worse it is.
It drove me crazy and after reading the forum i found an easy fix replace the timing chain Tensioner. the rear was easy.
the front way a huge pain to get out. i did get it out. when i put the new one it you have to push in to get it to start thredding in. I tried and tried and when i thought i had it i start to thred it in after 5 turns it got very hard. took it out and tried again and again kept having the same problem.
I decided that it was just hard and put the impact gun and it went about half way in the the impact gun did not have the power to get it in any more.
Well i am sure the Tensioner is cross threaded and now i have no idea what to do.
I need some help
what are my options? the only thing i can thing of it to remove the cylinder head and replace. does anyone have any other idea?
it this my best option? if so where is the best place to get a refurbished head?
what else should i did when i am in the engine like this? should i replace do the front Timing Chain Kit when i am in the engine like this?
HELP is i need my truck back ASAP
I need some help
